Tach hook up
MY6.2SS
144
87
60
Hello,
On my 84 SS, the original owner did away with the computer and the tach is unhooked.
It now has a Holley carb and a Mallory Unilite Electronic Ignition with a external coil.
Can I hook the tach up to this, if so where do I hook the tach wire to?
Thanks for your help, David
Hello,
On your firewall look for the tach filter. It looks like a small capsule with a wire that I believe is brown that would have hooked to the original hei distributor. You would have to hook that to the external coil. Under the dash I believe the tach wire is white. Someone can correct me if im wrong, good luck with the tack.
I have the tach wire…just don’t know what to hook it to with this set up.
