Guys,
I'm having a problem with the tachometer in my 1981 Cutlass Calais. The steering column was changed out (has a column shift column now, shifter is still on the floor). Rally gauges. All other gauges work but the tach. 231 V6 car if that matters. Any help?
Edit: When I turn the key on, the tach goes from about 1500 RPM to zero. When I turn it off, it does the opposite.
