hi thereanthonychacon80 said:well, i think on the Diesel the tech works a little differently. Make sure the TACH port (negative side of the Distributer) has a wire that goes into the passenger compartment to the Tachometer. Also make sure the Jumper 6/8 is on 8 and maybe solder it so it stays put.
hianthonychacon80 said:you might be right, since I do not think the motor had a "distributer" of any kind, but a vacuum pump where the distributer would be. Right?
hi thereanthonychacon80 said:According to my 80 service manual...
There is a white .8 wire from the Generator to the Cluster. In the line there is a C323 with the symbol ">>" over the wire. Is that a resistor?
Once to the TACH it grounds to a 8 Black and then 3 black wire.
On the H engine (305) R and others the white wire comes directly off the distributer but there is an additional ">>" with the numbers C480 next to it along the wire on its way to the TACH
It sounds like the problem is in the TACH itself? Check to be sure the prongs on the circuit board on back are making contact with the printed board. Solder them down tight?
