I have been having a problem with the tailshaft leaking on my trans. The weird thing is that it happened with two different transmissions. On the first trans, I replaced the seal and the o-ring for the housing. Still leaked after. Second trans only had a few thousand miles on it after being rebuilt. It was not leaking before I got it, and now it is. I am starting to think it is a problem with the driveshaft slip yoke. Last time I inspected it, there was no obvious wear from the seal and it felt perfectly smooth.
Is there any wear that can happen with the slip yoke that I would not be able to notice without measuring? Is there anything else that could cause these leaks?
