Only if the tall deck block has about 1" thick deck to start with.KINGDADDY said:CAN YOU DECK A TALL DECK BLOCK TO A STANDARD BLOCK ?????
DRIVEN said:Only if the tall deck block has about 1" thick deck to start with.KINGDADDY said:CAN YOU DECK A TALL DECK BLOCK TO A STANDARD BLOCK ?????
DRIVEN said:Sorry, sarcasm is hard to type :lol: . The answer to your question is no, you can't mill a tall deck by .400". The deck would end up being too thin (if there was any left at all). You would be left with a very weak and unstable deck surface. I went looking for factory deck thickness specs and couldn't find them, but the Dart Big M spec was .625" (many sources just listed "adequate for all applications"). It would be easy enough to verify this. Just measure the thickness of the deck at the water jacket openings.
There's really no reason to modify it anyway. There are performance parts available for tall deck blocks. If you don't like the idea of a tall deck -- just don't use it.
