tci turbo 350 crossmember issue
MrRabbit24
137
16
33
Tulsa
Jegster th 350 crossmember double hump. ok so I order this cross member how do I bolted on 2 my chassisI've tried to find pictures online and could not find any, any info or pictures or diagrams are greatly appreciated I have my stock rubber mounts and bolts thank you in advance.
You dont use the rubber pads. You simply nut and bolt it with no rubber in between. Get some grade 8 bolts and nuts.
Well it doesn't seem like it bolts down strait across. And I don't need the steel coupling that go with the rubber?
No you dont use the inserts just a simple nut and bolt. The drivers side has 2 points it could mount in. One is further towards the front which is most likely the one you need. . And one is a foot or so towards the back behind that one.
Thank you for the info and your time on this I greatly appreciate it
I have never used a Jegster crossmember, I just modified my stock one but when I removed the rubber mounts under the crossmember I made duplicates in solid steel (all my engine and trans mounts are solid) so the trans still fits at the factory height otherwise the trans would be 3/8"-1/2" lower not only changing your pinion angle but it also makes it harder to put motor bolts in if they have a tight clearance like mine because of the angle change.
I got my stock one jacked it was for the 200 metric , Monte Carlos are hard to come by in tulsas junk yard.
