ok i have a 9" tail shaft th-400 and i have some questions, at least one for the moment.
what length yoke do i need? they come in lengths from 4"-6"roughly. also what is the spline count?
i'm sure i need to get a book on this transmission but for now i need some questions answered that dont require a book.
also what about changing the gear ratios? i know there are parts to convert the 1st and 2nd gears to a lower ratio for better acceleration. are these ok to use on the street? i'm asking because i have a 2.41 rear gear and if i can use a lower gear set in the transmission then i wouldnt have to mess with the rear end which would still be 2.41 final drive giving me a good highway gear but acceleration would be better.
2.48 x 2.41= 5.98 (th-400 first gear)
2.97 x 2.41= 7.16 (th-400 TCI first gear http://www.summitracing.com/parts/TCI-229700/ )
2.74 x 2.41= 6.60 (200c first gear, original transmission)
2.52 x 2.41= 6.07 (th-350 first gear, current transmission)
2.75 x 2.41= 6.62 (th-400 TCI first gear, different kit http://www.summitracing.com/parts/TCI-227500/ )
if i am to avoid spending big bucks on an OD transmission then i need to work with the gear i have now so this is my alternative option to a lower rear gear and OD transmission. the gear sets for the transmission are about 840 and 685 bucks, not cheap but maybe cheaper than spending 2K on a transmission and then more money on another gear, carrier, etc.
when i went to the th-350, the car had less acceleration and i could tell a difference and i have hated it since the transmission went in and it will get worse if i use the th-400 and do nothing about the gearing. i dont want to raise the cruising RPM i just want better acceleration so i can either put in lower gears in the transmission or get an OD transmission and a rear gear. i know nothing of these gear sets other than they've been around for quite a while but i dont know anyone who has used them and that kind of input is what i'm needing.
