thinkin about sellin my motor...whats a fair price?
84cutspreme
1,163
158
1974 #3970010 small block chevy 350, 2-bolt, 2pc rear main
Cast steel eagle crank 3.480
forged I-beam rods 5.7
hyper. alum. pistons 4.000, -5cc flat-top 4 valve reliefs with cast iron rings
Comp cams K12-206-2 hydraulic flat tappet cam & lifter kit with valve springs & double non-roller timing set
#333882 cast iron 76cc heads, 1.94/1.5 OEM valve & factory steel rockers
Melling high volume oil pump
stock oil pan
chrome tall valve covers
chrome timing cover
Compression is around 8.8:1
Selling motor almost complete
oil pan, crank, rods, pistons, cam, timing set, timing cover, heads (w/ assembled with springs, valves, rockers and pushrods), lifter and valve covers. no water pump, no fuel pump, no flexplate, no balancer, no intake or carb.
Just wondering if anyone has any insight as to what I should ask for if I sell it.
Thanks all
I've got about the same motor Uve got but I've got bigger heads, balanced crank, big soild lift cam 560 lift and I was askin 1300 for mine so I'd ask anywhere from 700-1000 for the motor u have
.............. that motor would only go for like $300 - 600 here I think you'll have to post pics for one and second of all post your location b/c I think demographics affect the price
