The bracket currently on my car is basically this one:
which is meant for cars with TV cable transmissions (Th200c, 200r4, 700r4, etc). Would I be able to use this bracket with a TH350 kickdown cable, or would I have to use my other bracket:
Every Throttle/Th350 bracket I've seen has the kickdown cable hole offset rearwards, presumably because the Th350 cable has a slot in it and has to have more room to move, whereas the TV cables clip on and move with the throttle.
Opinions?
Opinions?
