Tire combo?
driveit
Nov 7, 2013
76
6
38
Would the following combo look good for a 15x8 wheel?
205/60R15 front
225/60/R15 rear
This is for my 82 Malibu.
I am looking at the uniroyal tiger paw touring NT.
205/60R15 front
225/60/R15 rear
No and they're too narrow for an 8" rim.
The 60 and 65 numbers are the aspect ratio of the tire. This tells you the height of the tire from the bead to the top of the tread based on a percentage of the tire width. So if you have a 245/60R15 tire, your tire width would be 245 mm (9.6 in), the height would be 60% of 245 mm or 147 mm (~5.8 in). Double the tire height and add the diameter of your wheel for your overall wheel/tire height.
If the tires are the same size then the 65 is taller then the 60. Example 245/65/15 is 27.5 in tall and the 245/60/15 is 26.5 in tall. So using a 215/65/15 that tire is 26 in tall.
Doug
