tire question
mebe007
1,808
4
36
newport news, viginia
ok i have an 80 regal. right now she is sitting on 215/65/r15 all the wasy around. my fronts rub(car has moroso trick sproings all the way around). anyways i ways i am running corvette rally wheels 15x8 w/4''bs rear and 15x7 w/ 4"bs front. i was told i can fit a 275/60/15 in the rear which is what i am interested in doing. the car is a hefty 350 punched .60 specs are in sig. i am running an auburn pro posi 28 spline, w/ 3.73 gears, mosier hardened 28 spline axles, welded axle tubes, and a trick flow rear support cover. now my question is what tire should i look into getting? it will primarily be a weekend cruiser, and maybe go to the track a couple times a month during season. also im trying to figure out a slightly smaller front tire to help with the rub. i was thinking 205/60/r15. i like white letters but they are very limited. i was looking at bfg radial ta's as they are affordable, look excellent and classic and bfg make=s good rubber. anyways i was hoping for input on these tire choices and sizes. i want to run as fat in the back as i can get away with. thanks in advance guys
