To run or not run rear sway bar. That is the ??? Some people say the car hooks better without it others say it dont make no difference. Any suggestions. Thanks Josh
No longer planning on running signature build it is running and is currently being driven. Just wanted to see what you guys and gals thought. I agree with you on not seeing much benefit of the stocker.jrm81bu said:Stock rear sway bars will most likely only benefit lower powered cars. With what your planning on running, I don't think you will see much of a benefit from a stock bar. At least not by itself. A true ARB would would work or one of the thick aftermarket bars that don't bolt to the control arms would be the most beneficial.
Syspension is no longer stock. It has southside machine lift bars for lowers and SSM uppers. Drag springs and bags also drag shocks. Sway bar is currently on it was just debateing for track purpose if i should just ditch it.dogshit said:No downside to running a rear sway bar. It can only help traction and handling. Assuming the rest of the suspension system is stockish.
