Re: Top 5 GM favorites. in Torque, Hp, and Bang for the buck
I think the 3800 is definitely the best engine made during its century. I had one and except spark plugs never had to do any maintenance besides oil change, which it never burned a drop of and also never used it's coolant either bc the engine ran so smooth the fan was good enough. Also, I had the n/a version so when the car didnt charge right due to an old batt. terminal cable all I had to do was run w the car forward in neutral jump in and it would crank while rolling, then switch to drive and give it some rpm's and I was gone *_^
2nd of all ... nobody has mentioned the vortec 4300 v6 which is an obvious 2nd best in terms of reliability, although a lot of people would reverse the order of my top 2 choices^ I have heard about the 'spider' fuel system problem but it never happened to me or my buddies we all had blazers around the same time clocking over 120,000 miles one of them 185k w/o this issue so I believe that issue is more rare than people exagerate it
3rd... no I'm not going to say 350 b/c I'm tired of seeing them to be honest they are fantastic but I'd rather hear a 383 stroked out any day by the right engine builders sounds what can only be described w the adjective 'magnificent' especially when you live in Indiana where there are plenty of '383s' built by questionable sources, so you have that comparison of crap to the real deal and know a good one when you hear it (not see it, hear it
4th my dad's 6.0 litre Firebird w/ the 403 engine sounded very nice and made a minor impact on my childhood. It was very powerful but for a guy w/ kids it was practical too bc it wasnt putting out that top end hp that gets people that speeding ticket in a moment of getting carried away!
I'll stop at 4 because it's a tie between the vortec 5.7 I had and L05 for last place. They were both engines that I should have had a fantastic experience w/ , but due to irritating security features (vats), oxygen sensors, and worn trans being behind both of them I'd have a hard time choosing which one I thought was better, since those problems kind of detracted from the exp of owning those engines. My vortec definitely wanted to run on higher octane gas which was probably being caused by a computer error or missing o2 sensor somewhere, while the L05 will chew up the crappiest most BS gas that would make other cars puke and burn it right up smoothly w/o issue. Being po` these days its hard for me to choose between them bc I know the vortec is way better design on paper but I did have a bit of a resentment against the particular one I had for causing me so many electrical problems and wanting to run rich!
6th my 307
terrible not even 150 hp I bet but it gets like 17- 19 a gallon, although the vortec did that with 43 more ci right , so... :lol:
