Touch Screen Electric Fan Controller
i think its too much bs for just a variable resistor. :wtf:
IF you were gonna go nuts and put a multi zone heat/AC system into the car it might be worth it, but WHY?!?!?!!?
there's absolutlely no reason to use it for the engine fans and it's major overkill for the regular HVAC system in the car.
could it be wired into the car? looks pretty simple, power, ground, switch power, inputs and outputs. but the issue is having the proper input voltages and fans designed for the outputs.
oh it's very cool, just not worth it unless you're doing a multi zone system.
if you have the money to burn and are making a 4-door "family cruiser/hot rod" with all the gadgets---i'd definitely go for it.
you know it's for a computer, so unless you are a true engineering geek, it will not work in a car. to many amps.
Not at all dude, it’s just a picture of a standard 4-way blower switch.
It was my way of being funny. 🙂
