jrm81bu said:
As far as oil control get a windage tray and crank scraper, and an oil pan with baffles or trap doors. Are you really wanting to be competitive or doin it just for fun?
Is there a difference? :lol: Seriously though, I want to keep it reliable for when I terrorize the back roads with it, and will probably develop the car to be as good as possible cheaply. If I enjoy a few track days, etc, I will probably consider building a dedicated car for it out of either an S13 240sx or a AE-86 Corolla, which could also double as a pizza delivery beater. I figure I will be able to raise the money for another car by selling off my AMC Spirit.
As for my chassis setup, I plan on a tall spindle conversion with my own bump steer correction plan, thus hopefully negating the only drawback to the negative roll geometry conversion.. I have a steering box from a MCSS that will replace the leaky one from a WS6 Trans Am that is in it now, and will be connected to the column by a brand new steering shaft I bought, complete with coupler and U joint. I will use a stock 1.25in front sway bar with an aftermarket rear of at least one inch (to counter the natural understeer tendency), and keep my Eibach springs for now. I also plan on a set of tubular lower rear arms with spherical bearings to add some articulation to the rear suspension, and a set of 4th gen Camaro rear disc brakes to round out the 12 in 1LE rotors and
Caprice calipers up front. I also plan on a power steering cooler, and the car is already set up for an oil cooler I pulled from a 9C1 Cop
Caprice. I am using an aluminum hood for weight reduction, and will also add the aluminum front bumper and core support when I find them. My TH 200 4R is not long for this world (metal shavings in fluid), so good riddance to bad rubbish! It will be replaced with a Borg Warner T-5, light weight flywheel and a Centerforce dual friction clutch. I also plan on using a Camaro hand E brake and eliminating the stock foot E Brake. I still haven't figured out what front seats to use as they need to be very supportive, and likewise I have to pick out a new steering wheel too. Any suggestions on where my ideas are wrong on the chassis? Remember, this is not a daily driver, but a car to drive hard on back roads when I am pissed off and a backup car on rare occasions.
