trans mounts and install
chicago2tacoma
102
When I do my 350/th350 swap will I need to change trans mounts from the th200 its got now and will the mounts go into the same holes as existing mounts or will they have to be moved??....1979 cutlass supreme.....would also like tgo know same question for moter mounts swaping 260 olds for sbc
For trans If you have a 200-4r the 350 will bolt in the same place and use same crossmember...if it is 200C(non-overdrive) trans then you will need a new trans crossmember.
Here are sbc motor mount position
I don't know what trans I have its small and says metric on it its a 3 speed no overdrive. And what crossmember do I need to get for the th350 and how much will it cost......now I called jegs guy said that the crossmember for 200c will work for th350 I just need to get th350 mounts....any input......all th350 g body crossmembers in jegs say at bottom will not fit any supreme why is that???.....and is the79 cutlass supreme a G body or an A body..........
So I'm at the point were I have to take the frame mounts off....but the way there on there you need to hold the nut underneath to loosen the bolt.....but there's no holes or space to get a wrench in there and hold the nut.....so I think ill use a die grinder and cut da bolts out......its on a 79 cutlass supreme
Can you use the same drive shaft if going from 200-4r to TH350?
