TTop Help
JPetro
14
7
46
Hello all, this is on my 84 Hurst. I have no idea what type of handle and lock set it is and was hoping someone can recognize what it is. The "lock hole" in the vinyl appears to be of low quality and not Factory. The key holes are both drilled out also.
Maybe a dumb question but do you have factory t-tops or C&C t-tops?
They are factory. I'm thinking these were some type of retail lock from the 80s maybe sold in Napa or something because I can't find any photos online.
I've never seen locks added to non locking factory t-tops before, but not surprised it was a thing. Interesting....want to keep it that way or find some non modified tops to swap on? Or even if there was a busted (glass) set you could use for parts to return yours back to stock.
Thinking about leaving it and grabbing some vinyl trim to replace these out. The lock part is just screwed on and can easily be removed.
Reactions: PBGBodyFan
factory ones looked like this... this set is for sale
I'll get the part numbers off the back and let you know
Could be "American". I have the 81 t tops in the firebird TA. No longer made. They were aftermarket supplier to dealers and other shops. Factory tops were Fisher Body or Hurst. Even though F Body is different from G Body, I have same trouble with mine as parts are very difficult if not impossible to find.
Found some stock OEM...
Reactions: pagrunt
