Ive been running my 1986 307 for a little bit now, it drives real smooth in my 83 Cutlass. Stock ECM and PROM chip.
I have been tinkering with timing a little bit and thought Id share what Ive noticed. Maybe you all have had similar results?
The emissions sticker says to set timing at 20 degrees BTDC at 1100RPM.
When I do this, I cannot hold an idle. It appears that the ECM pulls so much timing at 550 or 600 rpm idle, that the engine just quits.
Messing around with it some more, I found it started well cold or hot with what I consider a "normal" amount of timing at idle - 8 to 12 degrees BTDC. Throttle response down low in the rpms, right off idle, really wasnt great. once the rpms got above 1100 or so more timing came in and the engine felt good.
Today I went to an initial setting of 20 degrees, just for the fun of it. Engine starts right up cold or hot. great response down low. No audible detonation under load. Just all around much more "peppy". I took a look at total timing at higher rpms and it looks like 43 or so degrees all in.
any thoughts on this? Whats the farthest you have pushed your initial setting on an Electric timing control 307?
