Turbo 350 Shifting Help!!!
thebaron
Jul 11, 2006
89
We just finished installing the 83' Cutlass Supreme Turbo 350 into my 84 Pontiac Grand. We took the Linkage bracket off the TH-200 and installed it on the Turbo 350. She runs great, but have a problem:
The Floor shifter does NOT work properly and my friend tried a bunch of stuff. You have to shift the car using the Column Ring on the Steering Column.
Any ideas?
Thanks
Found part of the issue, the clip on the cable going to the shifter came off. Put the clip on, but it won't go into Park.
Might need new cable anyhow, but who carries them (if we can avoid the D word).
Thanks
shifter
You need to get the bracket for a 350. The bracket is different on the 200 and also a cable for a 350
