So I've slowly been tinkering with my Regal here and there, mainly trying to get it to stay running under its own power for more than a few minutes at a time. The car just can't seem to keep the fuel pumping. For starters, the original carb was badly in need of a rebuild, but rather than do that, I swapped on the rebuilt one that I kept from old Sport Coupe. I had already installed a new fuel pump last fall before I trailered it home. We put in a few gallons of fresh fuel since the car had been sitting for over 7 years, filled the bowl on the carb, made sure the float wasn't stuck, and she kicked over and ran beautifully . . . For about three minutes. Wouldn't start again without filling the carb again.
So I'm thinking, this is a 31 year old, all original car that spent it's life in the rust belt, and sat outside on a farm for the last 7 years. That's 8 years older and a year longer than my Charger sat when it was abandoned, and the Charger's fuel system had to be completely gone through. The fuel sock on the Regal is probably just gummed up with varnish, or worse yet, buried in a layer of rust. So I made plans to drop the tank, clean it out with acid, install some fuel tank sealer, and put in a new sending unit- Just like I had to with the Charger. Call me a masochist, but I was in fact looking forward to it.
So last night, I got off work early, got some beer and a few friends together, and started tearing into the car. First thing that suprised me was that the bolts for the straps put up almost no fight at all. Once I got the remnants of the rotted exhaust out of the way, I probably had the tank out in ten minutes. Knocked out the lock ring and pulled out the sending unit, and the thing looks brand new. Not a speck of rust on the tubes, no evidence of anything plugging the sock, and the float moves smooth and free its full range of travel. Shined a light inside the tank, and could not believe how clean it was. The fuel was perfectly clear, and the tank was clean and shiny throughout. Unbelieveable.
I'm going to pump some CLR through the lines followed by a rinse of fresh gasoline just to be sure they're not plugged, and put on a new fuel sock since I have it out anyway, but I'm thinking the fuel pump might be defective.
I've also taken a ton of pics even for the minor amount of work done so far, so I'll be starting a work log on the car as soon as I get around to uploading them.
Just wanted to share.
