I know quite a few of you guys convert to chevy 350's from the v6 boat-anchor, but this write up is for the guys converting to a oldsmobile small block from the v6 8)
Basic Differences
-The oldsmobile starter is on the drivers side (Buick on passenger)
-Oldsmobile fuel pump is on the passenger's side (Buick on drivers)
I ran rubber line across temporarily, but it is best to bend up some hardline across the bay somehow, or just re-do the line from the tank.
-Battery is on drivers side for oldsmobile (Buick on passenger)
You can either run a long (+) cable over to the starter or you can just switch the battery to the drivers side. It's better to just switch it.
-Swap to V8 radiator and shroud & hoses (Have heard of the v6 rad. being used for a v8, but I'd rather be safe than sorry)
-Obviously you must change out the frame mounts for correct oldsmobile v8 pieces.
Incorrect These only line up with 1 frame hole, can be welded if needed.
Correct
-Buick transmission can be used if necessary. Or any BOP or dual bolt-pattern (Chevy & BOP) transmission can be used (if paired with the correct driveshaft and crossmember)
-Buick wiring harness can be used. The only wires to shorten are the starter wires (solder don't crimp) All the other sensor wiring I doubled back on itself a few times and stuffed it in the convulted tubing.
You can see how long the wires are in this pic
This is how I doubled them back, so to speak
Basic Differences
Correct
