Looking for any info as to what may connect to this fitting, 307 v8. I've been searching for another connection, or a random hose, to no avail. The splitter thing between the EGR and PCV. Thanks in advance.
If you're refering to the big breather on the valve cover, then it goes to the air cleaner via a steel 'hose'. Technically, you don't really need to connect it. You can just leave it to vent under the hood.
I'm referring to the little plastic canister to the left of it that has two fittings on one side, one with a hose, and one without, right below it. I would have drawn an arrow to it, if i knew how to photoshop or whatever.
Personally, I'd remove all of those little things I collectively refer to as 'gizmos', but if you're intent on keeping all that stuff then look no further than your very own emmissions decal;
