The Car
1986 Oldsmobile Cutlass 442
I have a question about my carburetor vacuum ports. I dont have an original carburetor, Its 4 Barrel, and has 4 vacuum ports two which have vacuum at idle and open throttle, the other two have no vacuum until you accelerate.
I was wondering what hoses go connected to these ports.
My car is off the computer and EGR is capped off.
I have a Vacuum Advance Distributor so that takes care of one of four ports, I also have my heater/ac vents hooked up to the other vacuum port that always has vacuum.
So now I have two ports that have no vacuum at idle but only on acceleration. What can I use these two ports for or should I cap them off.
Also,
Is the Distributor hooked up to the right vacuum port?
I read some other threads do Power Brakes have a hose thats supposed to be hooked up to a Vacuum Port is this true?
All info and suggestions welcome.
Also,
