Okay so here's the deal.
I bought i new carburetor from summit and it is longer (front to back) thank my old carb.
I was running my vacuum lines from a three way "tree" behind the carb. Now the new carb wont allow for that.
The new carb has one auxillary vacuum port but before i use that. is there anywhere else I can hook up my brake and transmission vacuum lines? Here are some pics
^this is where the lines used to be hooked up. you can see where i plugged it and how the carb is right above it.^
here is the port i was using but is too tall.
^here you can see the vacuum aux port on the carb. (the little brass plug) how ever it appears that if i put on the included vacuum connection it will hit the coil and cause issues.^
^and i dont even know what this little plate is for. its on the passenger side of the intake manifold. looks like it could be for vacuum?^
