Is there a source for the small white ‘clip’ that holds this piece together? I notice most of the pieces online do not show this piece.Application? Year, model? That always helps. Not all G-body parts are the same.
It's called a rotary select switch, but different part numbers for different cars.
From the looks of it, you either got a Malibu or Monte with a SBC. So I'm going to take an educated guess.
Luckily, it's the same p/n as an Olds Cutlass. GM p/n 16001570. AC Delco #15-7004. Colors could be black or brown like yours. Works the same.
GM still sells them for $59.74 list price.
Check ebay. You can get them for around 25-30-ish bucks.
Here's one. $24.31 plus tax, unless you make him an offer he can't refuse.
OEM ACDelco Heater/ac Blower Switch Part# 16001570 for sale online | eBay
Find many great new & used options and get the best deals for OEM ACDelco Heater/ac Blower Switch Part# 16001570 at the best online prices at eBay! Free shipping for many products!www.ebay.com
In a word- NO. Piece is not sold separate.Is there a source for the small white ‘clip’ that holds this piece together? I notice most of the pieces online do not show this piece.
Thanks in advance.
-Matt
1982 Monte CarloApplication? Year, model? That always helps. Not all G-body parts are the same.
Does it need the little white peice?Is there a source for the small white ‘clip’ that holds this piece together? I notice most of the pieces online do not show this piece.
Thanks in advance.
-Matt
I think it helps to hold it together technically.Does it need the little white peice?
Figure out the problemI think it helps to hold it together technically.
When I rebuilt the selector by cleaning it and putting new grease inside so it worked like new my clip broke.
I got another unit complete from the junkyard and was able to salvage the clip to use in mine.
