Stuck the key in the other day and the lock won't turn. As in won't even wiggle with the key in it. Not sure if the alignment went awry or something broke inside. I plan to unbolt the latch from the glass to get it up and out of the way, then try to 'pick' the side latches open on the gate with some shim stock so I can drop it and get the plastic interior panel off. Anyone had to try this stunt and have any advice/warnings?
