what's a good street tire to use.Mickey Thompson 1568 - Mickey Thompson Sportsman I Tires are the tires i have been using.i want a good 10 inch tire i can put on the back.anyone have anything to suggest.
I really like the Mickey Thompson I tread tires....They get hot and turn up the traction................However, I am running the Nitto Extreme Drag Radial 275-60-15. They are badass in the dry or Wet conditions making them the great street rod tire 🙂
I looked in your pics & for a signature. I don't remember what your setup is what kind of power etc. I also don't know what a 1568 is I did not see it on MT's page. Sorry I didn't see a Sportsman I either. You said a good street tire, the Sportsman ST radial looks good is all season and comes in a 295/50/15. I have been a fan of the Firestone Firehawk Indys but they should be comprable. I don't have the prices on the MTs but I would assume the Firestone can be had for less.
355 chevy ati 3800 stall 4.56 posi msd 6a box,distributor#8460 blaster 2 coil msd 8.8 black wires autometer gauges oil,water temp,fuel with isolator autometer tach with shift light worked 750 holley dp,holley regulator & holley blue series fuel pump fram canister fuel filter rci 16 gallon fuel cell with sending unit 1/2 alum line with #8 braided lones,earl's & aeroquipe edelbrock old style torker intake block paralell decked & line bore .30 over manley 10.5:1 flat top pistons,steel crank.pink rods assembly balanced to 8000 rpms canton 7 qt deep oil pan moroso high volume oil pump reed hydraulic camshaft special grind rhoads high intensity lifters crane roller rockers rare #441 casting heads off record holding stocker manley stainless valves 3 angle valve job,screw in studs cyclone headers s/s locking bolts sfi certified fly wheel ati tree master 10 inch 3800 stall fresh turbo 350 with turbo action cheetah series manual valve body new drive shaft incl yoke tube & u joint 67 chevelle wagon 10 bolt 8.2 ring gear 4.56 new carrier and axle bearings all spring and clutches long wheel studs center line drag 15x8.5 m/t l 60 t bone tires and 15x3 m/t front runners along with hurst pro matic 2 shifter mid 12's also i went with umi proformance rear end kit to center up the rear end all in my 83 cutlass
You know the internet/computer gets us sometimes. I read it as sportsman one (I) instead of the letter i. I would agree its sounds like the perfect tire for how you are going to use that car. Street tire kind of threw me off also even though you are going to use this tire as a limited use street tire. It fits your build perfectly. You might consider putting at least some key build specs in your signature line. 8)
i first saw these tires years ago when my brother bought a 71 buick with a big block in it.i would say about 20 years ago.really been using them ever since.they grab like crazy on the street and as for the track all you need to do is heat them alittle and they work just fine.i tought maybe there was something new out there someone had.
Something you might want to check out is the Nitto 555 NT Extreme Drag Radial tire. Comes in 295/50/15 and if your wheel wells permit, also in 325/50/15. Looks sick, grips well, does alright in rain and doesn't wear out as fast as other's (but still wears fast).
