Where are the power steering adjusting bolts?
trocutlass63
129
31
Metro Detroit
The power steering belt broke on my 307 and I'm trying to replace it, now I know cars pretty well but I cannot for the life of me figure out how to loosen/tighten the power steering pump. I found one bolt underneath the pulley at about the 1 o'clock position and loosened it and I also loosened a bolt with a nut on the back that was at the bottom of the pump just below the pulley but it still will not budge. Are there any more bolts that need to be loosened or is it just stuck? I don't want to start prying unless I know I have all the bolts loosened that I need to. Any help is appreciated.
There's a bolt behind the pulley at roughly the 12 o'clock position that you access by lining up the hole in the pulley with the bolt.
