Where to get new door hinges?
Peter
1,175
74
48
33
MA
im not sure whether the dealer has them or not but i have an 82 cutlass that will need them at some point and wanted to have a source to know before i actually want do them
thanks
It's worth a shot to see if you can still get some at your local dealer, but don't hold your breath...
You can dish out about $100+ each for NOS ones on ePay, or just find some decent ones at the junkyard and rebuild them with new pins and bushings before you install them.
2-doors and 4-doors use the same hinges, and since the doors are lighter and shorter on the 4-doors, the hinges are often not nearly as worn out as a 2-door car would be.
Almost positive Mike's Montes has them all, gbodyparts might too
get a set off of a 4 door and rebuild them. You can rebuild a set in your spare time for under 50 bucks even less if you dont have to buy the hinges. I rebuilt mine for around 25 bucks.
