Hello,
i've done some upgrades for my regal and having the Problem which timing curve should i adjust.
Engine is a '84 305 SBC LG4 none electronic, none cat.
Stock head & valve, cam, 8,6:1 compression, sparks
SMI-4bbl-Rochester-Carburetor Stage 2 (redone and calibrated carb, http://www.smicarburetor.com/ )
GM Performance 10185063 dual Plane intake with functional EGR
Corvette Ram horns 2,5" with 2x2,5" exhaust
MSD 8365 HEI with vacuum advance
Super (in Germany 95octane) Gasoline
initial for the stock engine should be 4°+-1 @ 450-550
is this ok? or should this be another
which stop advance bushings should i use?
which centrifugal adjust makes sense?
vac advance should be adjusted in drive with a wideband sensor i think, but are they any experience here?
thxs for help 🙂
thxs for help 🙂
