No, you should be fine..i have 17x8 with 4.5 backspace and nothing rubs. It will depend on what tires you have as well. I have 235/45/17 and i get no rub.
Cool, i should be good then, im running a 215 65 15.
I just didnt know cause i test fitted my 15x10s on a 275 60 15 on the rear and had just a finger gap to the frame lol
They won't rub the frame unless you have a 245/255 tire in front.
They can come close to the tie rod or Aftermarket A-Arm especially with a tall upper ball joint. Some trimming/shaving might be needed.. Stock A-arm/stock ball joint it should be OK.
