i have 15x9 centerline convo pros whats the biggest tire that i can fit on this rim? right now they have et street drag radials but theyre pretty worn, theyre 28 tall 11.50 tread width
85cut420 said:I don't think so. 295 mm is 29.5 cm. An inch is 2.54 cm, so 29.5 divided by 2.54 equals 11.62 inches, which seems a little too wide for a 9" rim. I am running 235/55 18s on my 18x9s, so I doubt the same width rim will fit a tire 60 mm (or about 2.5 in) wider.
FE3X CLONE said:85cut420 said:I don't think so. 295 mm is 29.5 cm. An inch is 2.54 cm, so 29.5 divided by 2.54 equals 11.62 inches, which seems a little too wide for a 9" rim. I am running 235/55 18s on my 18x9s, so I doubt the same width rim will fit a tire 60 mm (or about 2.5 in) wider.
If you check a few manufacture's of your tire size, the 9" rim that you have them mounted to is technically too wide. A 235/5518 is listed as fitting a 6.5" to 8.5" rim.
