Will it RUB?
87SS383
Jan 15, 2010
66
I'm buying a set of KMC Nova 20" rims for my Monte Carlo. I've picked out the 20"x8.5 in the front, & 20"x10 in the rear. I'm thinking about 275/45/20 on the back & 255/45/20 on the front. Will the rears rub? I'm in Afghanistan right now, so I dont have access to my vehicle for the geometry. Any ideas?
The back most likely will rub depending on the backspacing. i would go with the same size rims in the back as the front ones are. with the 10 in the rear the will hang out of the fender. If thats what you are looking for thats fine. To get them to fit will be no problem though. just get a cheap spacer or go with an adapter to keep the rim of the rear frame. Not a hard fix at all and you will not have no worrys about rubbing. Hope that helps and stay safe over there and thanks for your service.
