Window not rolling up Completely
78_oldcruiser
131
Seven Springs NC
if it is the motor you can find out by having someone roll up the window while you start to apply a little upward pressure as it gets near the spot that it stops at(not too much, bad things could happen). if it goes all the way up then, it will be the motor going. if you are having track issues you can try wiggling the window when it is half way up and you will feel a little more give or wiggle than the other windows. if it is the gasket/seal then the top 2 will have been ruled out. if you could get us some pics of it up it might help us to find a better fix for the problem. hope this helps
81cutlass
4,649
13,565
Western MN
I have a similar problem. My car origianlly came with manual windows and swapped over to power when I swapped my supreme interior with my salon interior. Anyways...
I would pull the door panel and move the upper window stops up. If it still doesnt go up you have my problem, which is where the motor itself wont go up any more. If it doesnt seal front to back or isnt pulled in enough at the top thats adjustable.
You could also have a regulator issue, which is some greese or new parts.
You almost have to take the door panel off to figgure anything out.
