Yea that's a possible. ThanksWill this work?
Buick Restoration Parts Beltline Weatherstrip Inner or outer - Also Called Window Sweeps, Felts Or Fuzzies - Cut To Fit - Pair
Buick Beltline Weatherstrip Inner or outer - Also Called Window Sweeps, Felts Or Fuzzies - Cut To Fit - Pair 4' Strips, number 10-179X from RubberTheRightWay.comwww.rubbertherightway.com
Thanks I seen dixie has it for the windshield. Wondered if that would work. I'm g gonna buy new.It sounds like what you're looking for is the plastic profile stripping under the metal quarter window trim. It's pretty much the same as the windshield stripping, However, the way it's sold is generally enough for the windshield trim....or if you can find a few junkyard B-body cars of the '70's-'80's and pop the windshield trims and slide the plastic stripping out. It's a crapshoot as to what condition they'll be in. Many times they're dried out and deteriorated. You can try contacting Mike's Montes or Dixie for the windshield trim stripping. https://www.mikesmontes.com/Plastic-Windshield-Trim_p_782.html
