Well, I am broke now, and so I got to thinking about a little experiment I could kill time with for under $10. I have an old lawnmower I use for parts. It has a good engine, but a bad carb. Now, while this may sound crazy, it is a proven fact that an internal combustion engine can be made to run on the smoke from burnt wood. It is galled "Wood Gas". So, I am now thinking about trying it with the good engine on the crappy mower with 3 wheels on it and the bad carb off my good mower ( I swapped them when I got the other one because it was in better shape but didn't run because of the clogged carb). The carb will turn into a valve to throttle the amount of wood gas burned by the engine. I will use an old coffee can, a tuna fish can, some galvanized pipe, a metal funnel, and a bit of sheet metal to fabricate all of it.
Anyone want to follow along? If this works, I may go full scale if I can get a cheap old pickup truck to build into a drivable wood powered driver! I am sick and tired of these gas prices!!!
Wood powered G body, anyone?
I found it Here: http://www.woodgas.com/history5.htm
Also, here's a site about driving across Sweden in a wood powered 1968 Volvo: http://www.vedbil.se/indexe.shtml Don't worry, it's in English.
Here's a pic:
Here's a pic:
