I have been thinking about this for the last few days. The 442 Cutlass had a WOT cutout switch for the A/C compressor, but other models of Cutlass did not. The reason I suspect is to safeguard the compressor due to the higher WOT upshift speed of the performance TH200 4R transmissions. Now, if the compressor cannot handle the higher engine speeds (5,000 RPM vs 3,000 RPM for the base), then it would be a good idea to add a WOT cutout to any car with either a manual swap or a modded transmission with the higher than stock upshift. Since I am planning doing one or the other to my transmission, I have to wonder if there is another car I can source that GM cutout switch from? From the diagram in the service manual it is located on the gas pedal assembly inside the car. Did the Monte Carlo SS use the same sort of switch? How about the Camaro with a manual transmission? I would just go order one for a 23 year old 442, but I kinda doubt the dealer would still have it in stock, or available at all. Any ideas would be welcome.
