I'm sure some of you have had similar issues with your center consoles, so I have decided to share a few techniques I have used to have a lasting quality repair.
First up is a real common problem with the Chevy center consoles.
Under the black(or woodgrain) shifter trim piece, the console mounts to the shifter with 2 screws, this area tends to get cracked. This is a very simple repair that can be done with fiberglass. Ruff the area to be repaired with @150 grit sandpaper, lay some masking tape on the underside, and follow the directions on the fiberglass resin package.
This one I did using Bondo brand Fiberglass Jelly, which is what I recommend for this type of repair. On this particular repair I used two layers of the WOVEN Mat (do not use stranded matting unless you enjoy frustration). This stuff is very easy to use, and like a weld, when done properly the repair itself will actually be stronger than the areas around it.
Here is the under side with tape on it:
And here it is after hardening, with tape removed:
And here is the top side. Remember there is two layers of woven matting in there, reinforcing this repair like re-rod in concrete.
The top side will now be filed down some, just until it's flat. Then new mounting holes will be drilled from the underside, were I can clearly see were the old holes were. I will also now be using Philips head body screws there, they will be counter sunk to be flush, all to compensate for the additional thickness.
As you can see, my shifter trim plate still fits just fine. And my console is stronger there than ever.
Next up...The Hinge!
