im starting a thread on the progress of the car. the plan is to fix the body first and have the frame blasted and powder coated. interior comes next, then im going to build a 355 or 383, 4 speed swap and a 12 bolt rear. suspension will most likely come last. i plan to get the bodywork done and have the car painted, then use the original drivetrain wile i save for a motor build.
today i got the car in the garage with the help of a friend. i used the truck and an old tire to push it. my friend was steering the malibu.
we took the rear bumper off first because the fiberglass mount inside the bumper was broken on the driver side and the bumper was sagging. this was caused from a previous "accident" and not from using the truck to push the car. i had hooked the corner of the bumper on my trailer once and almost pulled the whole bumper off the car :shock:
i also test fitted some 15x10" wheels that i used to run on the camaro 8)
looks good.
