Wampa1 said:im never posted but view the forums often. I was wondering will the 12 uinch upgrade clear 15inch wheels? I never found an answer using the search so i thought i would ask. thanks
joe_padavano said:Wampa1 said:im never posted but view the forums often. I was wondering will the 12 uinch upgrade clear 15inch wheels? I never found an answer using the search so i thought i would ask. thanks
Which 12 inch upgrade? If you're talking about using the B-body spindles with the 1LE Camaro rotors, the B-body cars with those brakes came with 15" wheels (such as the one sitting in my driveway with OEM steel rims). Naturally, it depends on the wheel. For example, I have an old set of 15" aluminum slot mags that I was going to put on the B-body and they just barely rub on the calipers (a little filing will fix this). I also have a set of 15" aluminum GM rims that clear just fine.
