CopperNick
3,396
3,069
Canada
Finally managed to locate the remaining portion of that roll of self adhering/sealing tape that I just knew I had stashed somewhere; which turned out to be the torque wrench and tie wrap drawer in my basement master roller cab; Go figure.
Turns out it was not 3M but Locktite so spent a fair chunk of the subsequent afternoon chasing it on on line to get a part number............and succeeded! I have used this stuff before and it sticks to nothing but itself so great for doing insulating wraps. Come Monday I'll be calling the parts store to see if they carry the line or can order it in. All else fails, Amazon.
mclellan83
4,320
9,655
Pgh, PA
That 5/6 driven gear may need a puller to remove. So far I've gotten by with this and a heat gun.
View attachment 238536 View attachment 238537
I'm able to get at it from both sides.
We got as little into it as possible, didn't even really end up using all the parts I got. My buddy had debated on leaving the seal, but I said since we had it we might as well replace it even though the other one looked like it was fine. There weren't any shims under the input shaft so I guessing that Cochran screwed me on that deal and because of it then ate the pilot. We left the bearing and race because they were in good shape, threw it back together and as of now seems totally better. I know it is not a long term fix but wanted to spend as little time and money at the moment since both the Blazer and the Monte are always taking it
Reactions: 7 users
Supercharged111
4,967
7,780
Colorado Springs, CO
View attachment 238677 View attachment 238678 View attachment 238679 View attachment 238680 View attachment 238681 View attachment 238682 View attachment 238683 View attachment 238684 View attachment 238685 View attachment 238686
So the problem was no shim at all and the fix was to shim it?
mclellan83
4,320
9,655
Pgh, PA
No shim on that Input Shaft would have some serious problems...
We were going with the combination of no shim and the roller part of the bearing checking out to be nowhere we could find, like I said I don't plan it to be long term but great if it does.
Nov 4, 2012
6,040
12,834
Replaced the A/C condenser on my 2006 Lacrosse yesterday and got it charged up today. Last summer I needed to add a can every month or so and I didn’t need it for the winter, but it's getting warm and I wanted fix it properly. No great pictures, it was a PITA to change, had to pull the radiator and fans to get it out. System held 30 inches of vacuum for an hour so I charged it up and I've got cold air now.
Reactions: 7 users
Wraith
1,603
4,771
DFW, TX
Spent time on the hunting rig today. RGB rock lights and green spotlights plus some Oh Sh*t handles. Aso did a little beat of heat gun on the driver's rear flare from an unexpected sideways adventure last time out at the lease.
Clone TIE Pilot
3,881
2,646
Galaxy far far away
Replaced the driver side inner and outer tie rods on the Crown Vic, the inner was loose and had a flat spot. The passenger side rods were still tight but smooth. Took it in for an alignment.
