1980 Buick Century Not Working (3.8 2 barrel N/A) HELP!!
gbodybuick
37
10
8
simple 1st did you replace fuel filter? if clogged will slowly seep just enough to get some fuel in bowl but dosnt flow enough to maintain engine runing.
timing just doesnt jump out of the blue your getting spark, it does start even though briefly, so lets C you have spark! FOR Sure you have air its all around us.......... kink of leaves out fuel starvation in MYHO
Changed the fuel filter, carb was professionally cleaned and tuned, new fuel lines, spark plugs work fine (tested them against the block) and are only a year old. Only thing I could think of is the fuel pump, if it was broken though, I don't think it would be able to idle at all (which it is able to).
MrSony
6,854
6,793
Des Moines, Iowa
I've killed two fuel pumps on my buick 350, they can use the same pump as a 3.8, the 3.8 arm is just a bit longer. It would idle but under any throttle at all it would starve and die.
gbodybuick
37
10
8
How many miles did you have when it failed the first time? Did you have trouble starting it or just driving?
MrSony
6,854
6,793
Des Moines, Iowa
Probably no more than 10,000. cheap *ss chinese pump. it would hard start, take forever to pull fuel, and would run the bowl dry.
78Delta88
1,303
1,096
SW Arizona
I should be out at the yard Friday. I'll grab a 2bbl, build it and send it to you. There are several 231 of that vintage out here.
gbodybuick
37
10
8
I just unhooked the gas line and cranked the car, plenty of gas was pumping out.
gbodybuick
37
10
8
Thank you very much, however I don't think its the carb, I had it professionally rebuilt and tuned, its practically brand new.
gbodybuick
37
10
8
I removed the gas line from the carb and put it in a mason jar. I then cranked the engine and plenty of fuel shot in it. Does this mean my fuel pump is fine?
69hurstolds
8,278
17,833
Fuel pump is fine. Maybe too fine. It may be pumping TOO much fuel to the carb. Many of the aftermarket pumps exceed 8 psi. You really only need 5-7 psi, really. Not saying that's an issue, just a possibility.
