1982 Malibu Wagon Vent Window Frame and Motors
mlb602
22
5
Good day,
Anyone have or know where I can find the drivers side rear vent window frame? Also need the rear vent window motors for each side(along with the mounting plugs)??? Oh...also need all of the rubbber/plastic moldings to go around the vent windows.... Any help would be greatly appreciated. Thank you.
ssn696
Living in the Past
5,551
6,699
Permanent Temporary
All these vent windows rot off the lower pivot pin. Nothing in this assembly is reproduced, although you can hack the main window glass channel with aftermarket glass run (see curent thread on the home page). Sorry to ruin your evening...
mlb602
22
5
Thanks
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,180
9,808
Gainesville, Fl
I have found that in some instances the lower shaft becomes seized from years of not being opened and lubricated on a regular basis. Then when you try to open the vent window, the shaft shears off at the frame. Sometimes the shaft can be welded back on after removing the glass, of course. It would first have to be aligned at the proper angle before welding it.
  • Wow
