605 Steer'n Box Gave 78K Everyone opts for a Heavier unit?
Bonnewagon
Lost in the Labyrinth
10,614
14,417
Queens, NY
Hey man, see if he has the matching pump and hoses- then it will be an easy swap!
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,191
9,832
Gainesville, Fl
He might give you a good deal on everything. It doesn't hurt to ask. Make sure it's an SS.
You won't know the condition until it's bolted in and bled. You can inspect it for leaks, though.
Low_Bridge
Jan 22, 2014
69
13
8
Backwoods
Snagged an 84 Z28 box the seller confirmed was 2.5 turns to lock still has the Camaro Pitman $50 clams delivered
So... Lines / adapters & pitman arm hunting till it arrives .... and another Qt of transmission fluid to blow through the leaky 605....
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
That box is the same ratio as the G body quick ratio box but with different stops, the stops in the F body box will give you a larger turning radius. If it's a Z box it's a nice box and will give you more of the feel of the road. I ran one for a few years
Low_Bridge
Jan 22, 2014
69
13
8
Backwoods
Is there more than one part number I should be look'n for for the correct pitman arm for the new 84 Box to work?
Longroof79
Oct 14, 2008
12,191
9,832
Gainesville, Fl
There should only be one part number for that particular (800 series) G-body box. If I recall, someone not too long ago purchased a new(?) 800 pitman arm.
Low_Bridge
Jan 22, 2014
69
13
8
Backwoods
Thanks!
Bonnewagon
10,614
14,417
Queens, NY
Jack you geezer, how did you find that? I guess that company saw a need and filled it. Terrific!
Longroof79
Oct 14, 2008
12,191
9,832
Gainesville, Fl
Mark,
I can't take all of the credit. Steve was the one that first posted information from this company. I may be old, but I'm not ready to be put out to pasture yet...;)
I think you're right that they saw a need for these. This source should be made a sticky.
