Hi guys! Purchased this car last year sitting in a field. Stripped it all down, acid washed the interior and frame, welded up all the holes, por 15 sealed it all, and started going piece by peice
Engine is a gen 3 rebuilt lq4, ported 243 cathedral heads, isky 595-233 598-235 112 cam, fitech tall manifold, 55lb injectors, 102 mm Tb, tubular upper control arms, qa1 tall upper ball joints, c5 corvette accessory drive with power steering, vacuum brakes, circle D 4k stall 9.5 inch converter, rebuilt 4l80e, jegs g body conversion long tubes, summit ultimate ls fuel system using c5 regulator/filter, 20 gallon fuel cell, and going to be trying out the fitech 70051
Any questions or part info feel free to ask! Thanks for checking it out
