86 442 Door Hinge Pillar Same As ALL G-Bodys?
Mayfairs442
14
5
Trying to figure out if I can use any g-body A-pillar or if it has to be a 81-87 cutlass. I looked at one off an 79 Malibu 2 dr and it looks the same but still not confident. Also need to replace the tray under the back window but so far I've only found the tray for a 78-80 cutlass. Any advice would be helpful. Thanks in advance!
ck80
Moderator
Moderator
5,757
9,167
Yours a t-top car?
Have you removed the carpet yet?
I'd begin looking at maybe a wrecked donor car if I were you. That door jamb would leave rusty water and debris going somewhere.... either out the kick panel and under the rubber padding onto your floor pan or into the rocker void. Either place means rust is likely when there is rot the severity you showed elsewhere
Might be cheaper to be able to cut patches off as needed?
Mayfairs442
14
5
Yours a t-top car?
Yes its a T-top car, I haven't removed the carpet yet but looked under and didn't see anything through the bottom...I had the exact same idea and I found a donor but moved to late on it and it was gone by time I got ready to do something with it :blam:
pagrunt
9,315
15,845
Elderton, Pa
You'll need to really check out the windsheild header/front T top channel to see how bad that area is. Possible the windsheild A pillars may have also have related issues if the channel has any rot.
565bbchevy
G-Body of the Month
Aug 8, 2011
9,646
12,782
Michigan
The 86' Monte SS that I stripped had t-tops and was rusted in the t-top area and the A pillars were rusting from the inside out along with also needing floorboards from the leaks.
Thoroughly check everything before you get in over your head with unexpected rust repairs,
