86 Regal bracket racing
Dbkan
n00b
Dec 5, 2017
Next season I plan on taking this car out and I have some questions about my setup and consistency.
Here’s the info
Engine
454 .30 over, stock stroke flat top pistons fresh rebuild. 781 ported flowed flowed heads comp valvetrain. .630 bullet racing flat tappet cam.
750 quick fuel alcohol carb
Transmission
Turbo spline powerglide with TCI 254013 converter. Transbrake
Ignition
All MSD 7al2 box
Rear end
Quick performance 9 inch with 3.80 gears
10 inch tire. Morison springs and drag bags.
Car
All steel except hood
Racing seats up front keeping back seat
8 point cage
All glass
Any info I need to provide to make this better just tell.
Any advice definitely welcome!
So my questions are with so much weight being up front will I have any traction issues?
Recommendations for shocks rear and springs front and maybe rear. I’ve heard v6 springs and stock shocks on front are best because they help weight transfer.
What kind of spark plug to run with alcohol?
Will my 3.80 gear work okay with my current combination?
I think that’s all I have now. Car built with me in college working part time and buying and selling cars. It’s all the best parts I could afford/ leftovers from father. Thank you.
lilbowtie
3,460
3,965
Canton Mi
You will have to forgive me because I'm not a big block person. I believe that head is an open chamber and with a flat top piston your not going to have much compression. That cam you have I believe has about a 260 @ .050 duration which means it would like a lot more compression than you have. That being said it will be interesting since your leaving off a brake @4500+ and the alcohol will enhance the compression. I'm going to take a guess(it's only a low guess) at 450hp which would be low 11's and with the 3.90 gears you would be going through the traps @ 57-5800 depending on TC slip. Traction shouldn't be a problem depending on prep and the glide will help. I have been running Auto Lite Racing plugs with no problems. Your probably going to need a gas prime on a cold engine.
87 rocket
8
Here’s the info
Engine
Transmission
Ignition
All MSD 7al2 box
Rear end
Car
8 point cage
All glass
bracketchev1221
1,449
1,714
Yes a flat top piston and a 781 head will get you about low 8's in compression. The powerglide is going to need a decent amount of stall to make it work. Otherwise it will be sluggish getting it moving. Basic suspension being pretty reasonable is using Moroso trick Springs with 3 way adjustable shocks. Not very hi tech but it will get you going. My 70 Chevelle used that stuff front and rear with a factory sway bar and I went 10.50's at 127 with it. The air bags will help tune out the body roll these cars have as it tries to suck the passenger side tire up in to the body.
David.C
162
296
Few of silly questions... How is the motor mounted (plated, solid mounts, factory mounts)? Will you be running 1/8 or 1/4 mile? Is this a dedicated race car? How tall of a tire are you running (front & rear)?
I recommend replacing the bags in the rear with a anti-roll bar, it does a much better job of spreading the load across the rear end. They run about $200-$400
