Another Prototype Gasket in the (it's already here) Edition- Can't Believe They Haven't Repro'd This One
1988SS
May 9, 2020
65
11
Has it on my 88 MCSS....crusty but it's mostly there. Do you have to drill out that rivet to replace it?
8,278
17,833
Yes. Rivet must be removed, then reinstall a new rivet when reassembling. The rivet pulls it tight up against the trunklid effectively smooshing (technical term) the gasket in between.
A good time to clean up old wax and ingrained dirt around the trunk lock gasket area (your car's bellybutton lint), or even replace the trunk lock gasket itself. Which I have several of the 20030348 trunk lock cylinder gaskets, too, if you need any.
8,278
17,833
Oh, for those looking for a rivet size for the retainer, I BELIEVE (but not 4imprint certain) it's a 1/8" steel rivet. I'm not a rivet expert, but I do understand how to navigate the trade size charts. But GM doesn't quite hit the mark defining junk like rivets and other fasteners sometimes.
I couldn't find a GM p/n SPECIFICALLY for the G-body rivet itself, but it's listed for B, C, E, and X body. GM p/n 9426957 which superseded to 9441669. I can't see the G-body NOT using the same rivet. I fugged mine up on the H/O when I popped it out, to try and get the size I used and replace the gasket while I was in there, but the smallest I had on hand was a 3/16" and it was too big. Fit nicely in the retainer's hole, but the trunklid hole it would not go.
Info I found for rivet 9441669 is: Rivet, 1/8 x 0.255, 0.129. (I'm guessing this is 1/8" stem diameter, 0.255" length?, with 0.129 hole size.
Also for the same part number 9426957, got: Rivet, "Type P" (I assume this is GM's code for pop rivet, or pull rivet), 1-7/16 overall length (includes stem in the length for some stupid reason) x 5/64 diameter x 1/8 hole size. Weird.
And then there's THIS:
Ugly1
1,696
1,438
Lost in the woods of NH
Sounds to me you should contact some of the g body parts companies and sell them for possible profit. There’s a guy in Keene NH that does repop screws for Mopar’s and can’t make them fast enough. They are not a common screw to find so…And if you do a gasket and rivet kit well 😏
8,278
17,833
You can still buy the rivet 9441669 from GM. For around $7.20 list price. YUP. Crazy crap. I'm sure you can get one from somewhere else for cheaper.
88hurstolds
1,758
675
I've found $6 shipped from one of the few dealers if you bought 5 at $5 shipping. Not sure it's worth it...
8,278
17,833
I got the correct size with the bigger heads coming in the mail. Steel like original. 25 in the pack for $10 shipped. It’s nothing special IMO.
8,278
17,833
Fleabay. Actually it was a bit less than 10 bucks. Not sure about quality. If it were a special size and finish, etc., I'd probably spend the coin and get a GM one, but since it's not...
