Big block Chevy flexplates
bracketchev1221
1,449
1,714
Back in the late 80’s there wasn’t a lot available for the g body’s and that was when I had mine. Both of my cars had the 153 tooth flexplates/flywheels and used the stock starters. Are you able to fit 168 tooth flexplates and I guess mini starters in the g-body chassis?
565bbchevy
G-Body of the Month
Aug 8, 2011
9,646
12,782
Michigan
Yes, both my Monte and Regal have 168 tooth flexplates and mini starters.
GuysMonteSS
1,449
1,543
Kentville,Nova Scotia,Canada
bracketchev1221
1,449
1,714
Ok thanks. I have a 468 with a set of chevelle headers to go in, and was not sure about the flexplate. I was a kid at the time and I remember my dad and his friend balancing 153 tooth flexplates to go on 400’s they were running at the time.
pagrunt
9,315
15,846
Elderton, Pa
To be honest you should be able to run either a 168 or 153 tooth flexplate as long as it's balanced as needed for your big block. I know with auto's it won't make much difference with the weight but with a stick flywheel I noticed a difference going from a 153/10.4" clutch to 168/11" clutch flywheel on the 307 in my long gone '72 MC.
bracketchev1221
1,449
1,714
Well the issue was trying to find an externally balanced 153 tooth flexplate for a 454. If it was internally balanced I agree I could just use the 153. I ran a 10.5” clutch in my 78 with a 153 tooth 30lbs flywheel with my 465 hp 355.
