Cutlass Drag Car 85 442
Kratos
207
340
Central Pa
Hey all, Sorry for the long absence. work, racing, family, more work.....and I have been a ghost from this forum.
Just to bring you all up to speed, I had a Post titled Frankenstein 7.5 and it detailed the saga of my novice racing hobby and a certain scavenged junkyard 7.5 with an S10 Diff and a Mini spool.
Well, the car held up through two seasons now but it has undergone a few more changes. the SBC 350 that was in the car since I got it is still running and I am ecstatic about it.
It is a simple 350 with headers, an edlebrock intake and 600cfm carb spinning a 200 4r through 3.73 rear and 275-60-15 Mickey Thompson drag radials. It ran 10.50 in the 1/8 and 16.2 in the 1/4.
Now for the mods... The aforementioned 7.5 rear with S10 Diff and 3.73 gears has held up. I have added a Davis Ign (DUI Module) a different Edelbrock intake with a higher rise, and a Holley 670 Street Avenger.
I pulled the 200 4r and swapped in a turbo 350 cleaned up some choking exhaust pipe pieces, installed Comp Engineering drag Shocks and deleted the fan clutch for a flex fan
The car has been pretty consistent at 9.0 in the 1/8 and ran 14.30's )14.37-14.33) all day long at Maple Grove It did run an 8.76 (1/8) at Mason Dixon on Memorial day
I also managed to take home at least one Trophy with it after three seasons of trying! I am currently gathering pieces to build an 81 El Camino to race in 22 and I am stepping up to a street class and points racing. Thanks for Checking in I will try to post some of the build up of the Elco and how it does at the track .
  • Love
Reactions: 13 users
8,843
7,810
Nice gain. I went from an 11.3 in the 1/8 to a 9.4 in 1/8 my 88 CSC with a mild Olds 350/2004R and 3.42 open in the lousy 7.5".
39F
530
602
Pittsburgh PA
Get rid upper control arm stops and flip the air cleaner lid you'll be 13.90s no problem
John Wm. Zick
Drag Racer Forever !!!
100
71
Winter Haven, Florida
I also managed to take home at least one Trophy with it after three seasons of trying! I am currently gathering pieces to build an 81 El Camino to race in 22 and I am stepping up to a street class and points racing. Thanks for Checking in I will try to post some of the build up of the Elco and how it does at the track . View attachment 188929
I just found this "racing" part of the G-Body site ............ John Zick in Winter Haven, Florida
Kratos
207
340
Central Pa
My Racing buddy runs a 76 or 77 Cutlass with a Mild 350 Olds, turbo 350 and it runs consistent 8.80s. The 200 4r has a better first gear for launch that the T350. I lost a little ET when I changed, but with some tuning I got most of it back. What size tire in the rear?
8,843
7,810
It was a 25.8" MT ET Street Bias ply with an open rear, 2.1 60 ft. The 204/214 cam was two small, I think very low 9's were in it. Either way, the 88 CSC is gone. The new 400ish hp/tq Olds 350 going in the lighter 70S should run much faster even with a 3.08 posi. This car will be a long distance cruiser that will eventually see the track.
PBGBodyFan
788
1,221
Wisconsin
Any more info on the "simple" 350? I would think even with a mild 350, the 2004r and 3.73's you should be at worst a low 15 second car or even crack 14's with those good tires/traction and maybe nice conditions and if it's running well. Was the trans slipping at all? My low compression 350 with Vortec heads, 2004r/3.42's on street tires did a 14.55. Nice gains though after that.
bracketchev1221
1,449
1,714
The 7.5 will handle what you are doing fine as long as you don’t chatter it. Way back before anybody knew better I was running occasional 13.60’s with my 79 with a Monte ss 3.73 10 bolt. Was consistent in the 14.0-14.1 range when I raced it a lot. But if it was me, I’d shoot for as close to 14.0 that I could run so I could chase everybody. Does maple grove still use the first red light rule or the worst red light? It was first red light when I quit racing Super eliminator in 2018.
Kratos
207
340
Central Pa
I really don’t have any information on the engine. SBC from the early 70’s. As far as I can tell it’s all stock. Other than the high rise intake, 670 holley and dui module it stock. I did say it ran 16.2 but I forgot to mention that the TV cable was broken. It shifted super early and was lazy. When I replaced the TV cable and ran it in Drive , not shifting to OD, it ran 14.55 straight off the trailer. With a best of 14.38 at Beaver Springs on a really good pass and that might have been with an edelbrock 600
Kratos
207
340
Central Pa
I did win a round with a.007 red against a.022 red light so, yes they were running the worst red light rule. I have to laugh that I was being chased by low 10 second cars that day and beating them. The car was super consistent and I was cutting decent lights. Looking forward to the nostalgia/ geezer races in 2022
